Mosaic and Virtual Object - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: OLD visualization (https://forum.logicmachine.net/forumdisplay.php?fid=9) +--- Thread: Mosaic and Virtual Object (/showthread.php?tid=5741) |
Mosaic and Virtual Object - Frank68 - 14.11.2024 hello Does Mosaic have limitations in using virtual addresses? I had a client say that I only see the first 100 of the 32/1/* group Thanks RE: Mosaic and Virtual Object - Daniel - 14.11.2024 No, each widget has filter for dpts which are related to it. Most likely it is this. RE: Mosaic and Virtual Object - Frank68 - 15.11.2024 (14.11.2024, 12:38)Daniel Wrote: No, each widget has filter for dpts which are related to it. Most likely it is this. Hi I try to use 2 widdget one for see one temp value virtual address, and one for change set of temperature also virtual addre , setpoint is possible to connect view value not. DPT one 9.2 byte float floyting and other 14 4 byte float, now I need convert in the same dpt correct ? Thanks RE: Mosaic and Virtual Object - Daniel - 15.11.2024 in this case yes |
