Schedulers Limit - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: Schedulers Limit (/showthread.php?tid=5751) |
Schedulers Limit - jmir - 20.11.2024 Hi, I'd like to know if there is any limit in scheduler number in a LM5 Lite. Should it be able to manage up to 350 schedulers? Thanks. RE: Schedulers Limit - Daniel - 20.11.2024 Well there is no limit but as always your limit is on the CPU memory side. RE: Schedulers Limit - jmir - 21.11.2024 (20.11.2024, 13:02)Daniel Wrote: Well there is no limit but as always your limit is on the CPU memory side. Ok. And is there any way to add a delay between telegrams on TP line? I mean some kind of configuration not delaying write by code... Each schedule has to send a KNX value to the TP line and If the user configures many of them at same time they'll overload the bus... |
