Modbus Json datatypes - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Modbus Json datatypes (/showthread.php?tid=5769) |
Modbus Json datatypes - Intershade - 29.11.2024 Hi, I am, for the first time, creating a modbus json profile. And I have a question regarding how to correctly map a value of 20 bytes (10 registers) as a float. When reading the product pdf manual I map all 4-byte values. See following example: From pdf: Address: 30001, Descrption: "Line to neutral volts" Lenght (bytes): 4 Data format: Float Units: V Hi byte: 00 Lo byte: 00 This would be mapped as such: { "address": 30001, "name": "Line to neutral volts", "read_count": 2, "bus_datatype": "float32", "type": "inputregister", "units": "V" } But there are some values that have "Lenght" of 20 bytes. See example: Address: 38193, Descrption: "Total Last 1 month active Energy (Total, Rate1, Rate2, Rate3, Rate4)" Lenght (bytes): 20 Data format: Float Units: kWh Hi byte: 20 Lo byte: 00 How would I mapp that? Should I create 5 separate mappings for Total, Rate1, Rate2, Rate3 and Rate4. Assuming the addresses would be 38193 for Total and 38193+2 for Rate1 etc? Or is there a way to map a large 10-register value? RE: Modbus Json datatypes - Daniel - 29.11.2024 Start by using Read test to find correct settings. In your example do not use read_count only add "datatype": "float32", This defines how many registers will be read. One register is 2Bytes. The 20Byte registers - check in read test if you can divide them in a smaller chunks. |
