remote connection zerotier problem - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: remote connection zerotier problem (/showthread.php?tid=5789) |
remote connection zerotier problem - Frank68 - 12.12.2024 good morning I'm having problems on a remote LM5 Reactor system, Zeoriter tells me that I'm connected but when I call address on the browser, it shows me this http://10.147.20.36/apps/ and I'm left with a blank page. what could it be? Thanks RE: remote connection zerotier problem - Daniel - 12.12.2024 Try accessing it directly via IP/scada-main Any errors in the browser console? RE: remote connection zerotier problem - Frank68 - 12.12.2024 (12.12.2024, 10:11)Daniel Wrote: Try accessing it directly via IP/scada-mainvia scada-main nothing left to search for and I never get an answer. I have try different browser and PC RE: remote connection zerotier problem - Daniel - 12.12.2024 Any errors in the browser console? RE: remote connection zerotier problem - admin - 12.12.2024 Are you sure that the IP address is correct? Maybe it's your PC address, not LM. See if you can ping this IP address. RE: remote connection zerotier problem - Frank68 - 12.12.2024 (12.12.2024, 13:38)admin Wrote: Are you sure that the IP address is correct? Maybe it's your PC address, not LM. See if you can ping this IP address.Correct IP ZeroTier detects it online but does not show me anything, I do not have access to the console, it is a remote system, I connect via VPN with ZeroTier. RE: remote connection zerotier problem - Daniel - 12.12.2024 Press F12 while trying to connect to LM RE: remote connection zerotier problem - Frank68 - 12.12.2024 (12.12.2024, 14:48)Daniel Wrote: Press F12 while trying to connect to LM Caricamento non riuscito per lo <script> con sorgente “http://10.147.20.36/apps/js/apps.js.gz?v=20240222”. |
