Run script or update GA from http command - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Run script or update GA from http command (/showthread.php?tid=5791) |
Run script or update GA from http command - tomnord - 14.12.2024 Is it possible to execute a script or update a GA using http command? http://IPaddress etc etc etc? RE: Run script or update GA from http command - CristianAgata - 14.12.2024 (14.12.2024, 17:30)tomnord Wrote: Is it possible to execute a script or update a GA using http command? http://IPaddress etc etc etc? Hi, check this: https://kb.logicmachine.net/misc/remote/ BR Cristian RE: Run script or update GA from http command - tomnord - 15.12.2024 (14.12.2024, 17:55)CristianAgata Wrote:(14.12.2024, 17:30)tomnord Wrote: Is it possible to execute a script or update a GA using http command? http://IPaddress etc etc etc? Brilliant, missed that one when browsing! RE: Run script or update GA from http command - tomnord - 16.12.2024 (14.12.2024, 17:55)CristianAgata Wrote:(14.12.2024, 17:30)tomnord Wrote: Is it possible to execute a script or update a GA using http command? http://IPaddress etc etc etc? Do you always have to enter credentials when running remote services? I get prompted for login on LM even when password is in the url command. RE: Run script or update GA from http command - admin - 16.12.2024 Remote services are designed to be used for integration with other systems, not for user interaction. RE: Run script or update GA from http command - tomnord - 16.12.2024 (16.12.2024, 08:40)admin Wrote: Remote services are designed to be used for integration with other systems, not for user interaction. Is there any other way to run commands via url then? RE: Run script or update GA from http command - Daniel - 16.12.2024 You can try this but no security: https://forum.logicmachine.net/showthread.php?tid=3141&pid=20407#pid20407 RE: Run script or update GA from http command - tomnord - 16.12.2024 (16.12.2024, 12:04)Daniel Wrote: You can try this but no security: Thanks, I'll have a look. It's just for use on wifi. for triggering events with a QR-code or similar. RE: Run script or update GA from http command - admin - 17.12.2024 A more secure approach is to create a separate .lp file for each action (QR code) without any parameters. Code: <?
require('apps')
grp.write('1/1/1', true) |
