modbus polling and cpu overcharging - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: modbus polling and cpu overcharging (/showthread.php?tid=5800) |
modbus polling and cpu overcharging - gdimaria - 20.12.2024 hi, I have a LM whose CPU is often overloaded (it even restarts!). I have analyzed every possible cause, including infinite loop scripts, but nothing. The only thing I notice is a continuous telegram traffic from an external modbus gateway to which several devices are connected. There are several telegrams frequently updated and/or repeated. Could this be the cause of the overload? Is it possible to monitor the CPU load trend to determine when it overloads? Thanks in advance Peppe RE: modbus polling and cpu overcharging - admin - 20.12.2024 Install System load app and check which process is consuming max CPU/RAM. RE: modbus polling and cpu overcharging - gdimaria - 21.12.2024 (20.12.2024, 09:43)admin Wrote: Install System load app and check which process is consuming max CPU/RAM. I already done, those ones are always in pole position... enspecially nginx (there are several users simultaneously pointing their browser to LM). RE: modbus polling and cpu overcharging - Daniel - 23.12.2024 The CPU is nice and low. You should wait till the high CPU happens. RE: modbus polling and cpu overcharging - gdimaria - 23.12.2024 (23.12.2024, 08:52)Daniel Wrote: The CPU is nice and low. You should wait till the high CPU happens. It's hard to take a screenshot when it peaks. However, nginx is always very high in that case.. as the signed others. Often CUP/IO gets 3.50 and more... until it reboots! RE: modbus polling and cpu overcharging - AEK - 24.12.2024 (23.12.2024, 18:56)gdimaria Wrote:(23.12.2024, 08:52)Daniel Wrote: The CPU is nice and low. You should wait till the high CPU happens. It seems like you have loop in scripts or somthing like that. you have very high knx tp load/ make objects sort order by update time and see what GA often updates RE: modbus polling and cpu overcharging - Daniel - 24.12.2024 Send me your backup to PM. RE: modbus polling and cpu overcharging - gdimaria - 24.12.2024 (24.12.2024, 09:18)Daniel Wrote: Send me your backup to PM. I can't find the attachement button anymore in PM interface...
RE: modbus polling and cpu overcharging - Daniel - 24.12.2024 It was never there, use some cloud storage and send me a link. RE: modbus polling and cpu overcharging - gdimaria - 02.01.2025 (24.12.2024, 10:30)Daniel Wrote: It was never there, use some cloud storage and send me a link. Referring to our PM: I meant It would be nice to be able to associate a virtual object to the cpu/memory load, as is already possible with the cpu temperature. In order to be able to trend and thus understand the exact moments in which it overloads RE: modbus polling and cpu overcharging - Daniel - 02.01.2025 This is KNX TP UART chip temperature not the CPU itself. https://forum.logicmachine.net/showthread.php?tid=2233&pid=13948#pid13948 |
