general - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: general (/showthread.php?tid=5805) |
general - mariosp - 23.12.2024 Hello guys i have a problem, In mosaic i have 2 blinds tha worked perfectly and now stop working. Lm sends a telegram on knx but doesnt work, even if try on the groupmonitor to send up-down with LM as interface RE: general - Daniel - 23.12.2024 It sound like your blind actuator is broken or the motor. Go to your actuator and try controlling it, you should hear some clicks. RE: general - mariosp - 23.12.2024 (23.12.2024, 15:02)Daniel Wrote: It sound like your blind actuator is broken or the motor. Go to your actuator and try controlling it, you should hear some clicks. The blinds work perfectly from the buttons and from a touchscreen that i have in this room! RE: general - mariosp - 23.12.2024 (23.12.2024, 15:39)mariosp Wrote:The Solution was to add dummy and it work can you tell me why this happend?(23.12.2024, 15:02)Daniel Wrote: It sound like your blind actuator is broken or the motor. Go to your actuator and try controlling it, you should hear some clicks. 3 years now worked perfectly! RE: general - Daniel - 24.12.2024 Nothing happens on its own, there must have been some change. It is not possible to say anything without a detail info about the project. |
