grp.write not on KNX TP - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: grp.write not on KNX TP (/showthread.php?tid=583) |
grp.write not on KNX TP - bmodeco - 30.01.2017 Hi, I am using the grp.write command in a script to update a boolean. In the script i use grp.write('1/1/2', true, dt.bool) The script is triggered by a change in value (another groupaddres) and the script is being triggered (added some log-commands to see what is happening). The grp.write-command is being executed but is not visible on the groupmonitor (ETS through LM) and nothing happens. When changing the boolean-value in de objects-tab of the LM it is being send to KNX-TP and shows up in the ETS groupmonitor. I am not using any filtering on the LM (IP-TP or TP-IP). Any idea what can cause this? (probably something stupid i guess) Thanks, Bart RE: grp.write not on KNX TP - admin - 30.01.2017 Which FW version are you running? RE: grp.write not on KNX TP - bmodeco - 30.01.2017 (30.01.2017, 12:58)admin Wrote: Which FW version are you running? I need to check tonight at home - it is the LM5p-PMU you shipped to me early jan2017. So i guess it must be running the latest FW? RE: grp.write not on KNX TP - bmodeco - 30.01.2017 (30.01.2017, 13:07)bmodeco Wrote:(30.01.2017, 12:58)admin Wrote: Which FW version are you running? The firmware is the latest is guess 20170105. I removed the script and copied it into a new one (doing the same thing) and now it is working. |
