Modbus RS485 using USB Dongle - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Modbus RS485 using USB Dongle (/showthread.php?tid=5833) |
Modbus RS485 using USB Dongle - jmir - 13.01.2025 Hi, I'm using a USB Dongle as modbus RTU3, it's working fine but when I unplug the dongle and connect again the port name switches form " /dev/ttyUSB0" to "/dev/ttyUSB1"... Is there any way to fix the port name? When it happens the only way to make it working again is rebooting LM... RE: Modbus RS485 using USB Dongle - jmir - 15.01.2025 (13.01.2025, 09:23)jmir Wrote: Hi, Is there any way to solve it? RE: Modbus RS485 using USB Dongle - admin - 15.01.2025 USB is not a reliable solution. It can disconnect randomly due to electromagnetic noise presence. If you need more ports consider using LM5 DR. Alternatively you can use a third-party Modbus RTU-TCP gateway. RE: Modbus RS485 using USB Dongle - jmir - 15.01.2025 (15.01.2025, 11:39)admin Wrote: USB is not a reliable solution. It can disconnect randomly due to electromagnetic noise presence. If you need more ports consider using LM5 DR. Alternatively you can use a third-party Modbus RTU-TCP gateway. Ok thanks! RE: Modbus RS485 using USB Dongle - JRP - 21.01.2025 Hola When I experiment with other equipment (no LM, no SE), such as SBC and Zigbee USB dongles, I always recommend using a USB cable extender to connect it to the equipment. Quiz your sea of use. Greetings. |
