Modbus RTU and File Descriptor Support for Parallel Interface Monitorin - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Modbus RTU and File Descriptor Support for Parallel Interface Monitorin (/showthread.php?tid=5853) |
Modbus RTU and File Descriptor Support for Parallel Interface Monitorin - Blooddah - 21.01.2025 Hello, I am currently working with the LuaModbus library to communicate with Modbus RTU devices and have successfully implemented basic register reading functionality. Below is a simplified example of my current approach. Code: require('luamodbus')
-- Modbus RTU communication parameters
local port_rtu = "/dev/RS485-2"
local baud_rate = 9600
local parity = 'N'
local data_bits = 8
local stop_bit = 1
local slave_id = 78
local register_address = 19
local timeout = 5
-- Establish Modbus RTU connection
local mb = luamodbus.rtu()
mb:open(port_rtu, baud_rate, parity, data_bits, stop_bit)
mb:connect()
mb:setslave(slave_id)
mb:setresponsetimeout(timeout)
-- Read the register
local value, err = mb:readregisters(register_address, 1)
-- Display the result
if err then
print("Read error: " .. err)
print("Value read at register " .. register_address .. ": " .. value[1])
-- Close the connection
mb:close()Specifically, I am interested in achieving behavior similar to MQTT, where I can use "socket" to monitor multiple file descriptors and trigger events when data is available. Is it possible to retrieve a file descriptor for a Modbus RTU connection (similar to the MQTT socket), which I can integrate into an event loop? Code: --[[...]] -- Client initialization
while true do
connect_mqtt()
local timerfd = socket.fdmaskset(timer:getfd(), 'r')
local mclientfdset = mclient and socket.fdmaskset(mclient:getfd(), mclient:want_write() and 'rw' or 'r')
local res, timerstat, mclientstat = socket.selectfds(10, timerfd, mclientfdset)
if res then
if timerstat then
handle_timer_event()
if mclient and mclientstat then
if socket.fdmaskread(mclientstat) then
mclient:loop_read()
if socket.fdmaskwrite(mclientstat) then
mclient:loop_write()
mclient:loop_misc()
os.sleep(1)
endAny guidance or advice on how to implement this functionality with LuaModbus would be greatly appreciated. RE: Modbus RTU and File Descriptor Support for Parallel Interface Monitorin - admin - 21.01.2025 Not possible. Modbus library functions are blocking. You can't perform any other actions until read/write is finished. The only solution I see is to split each Modbus port handler into a different process. |
