general - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: general (/showthread.php?tid=5860) |
general - VoltTech - 27.01.2025 I would like your assistance in selecting the appropriate Logic Machine model for a small hotel unit with 43 rooms. Requirements:
RE: general - Daniel - 27.01.2025 All LMs are identical in term of power and software, the only difference are the I/Os and extra interfaces. If everything above is on KNX then simple LM Lite would do. If you need I/Os then select the one which fits you best. RE: general - VoltTech - 27.01.2025 (27.01.2025, 08:38)Daniel Wrote: All LMs are identical in term of power and software, the only difference are the I/Os and extra interfaces. If everything above is on KNX then simple LM Lite would do. If you need I/Os then select the one which fits you best. Thank you very much! |
