OpenVPN and ETS interface - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: OpenVPN and ETS interface (/showthread.php?tid=5862) |
OpenVPN and ETS interface - msybilla - 27.01.2025 Hello guys I have a LM5 configured LM5 with openvpn server. I can access UI via port 80, but unable to use it as ETS interface. My openvpn nettwork has a private IP range - 10.0.0.0/16. It seems that both LM5 and my PC got IP's within that network. I've tried both NAT and without. TCP & UDP setting in ETS. I also checked firewall on my PC to openVPN client, TCP/UDP 3671 OK FTP seems to be working as well. I tried using zero tier, but the connection is very slow and I'm unable to download any device due to unstable connection error in ETS. I read somewhere that zero tier does not like 4G internet connection. Is there something i'm not seeing? RE: OpenVPN and ETS interface - admin - 28.01.2025 You can try using WireGuard instead of OpenVPN. You need the latest firmware and manually updated package: https://forum.logicmachine.net/showthread.php?tid=5393&pid=35350#pid35350 RE: OpenVPN and ETS interface - msybilla - 28.01.2025 (28.01.2025, 14:06)admin Wrote: You can try using WireGuard instead of OpenVPN. You need the latest firmware and manually updated package: https://forum.logicmachine.net/showthread.php?tid=5393&pid=35350#pid35350 I dont have access to wireguard server. Have you somehow managed to download KNX via openvpn, or hasn't that been tested yet? If yes, could you provide config information? RE: OpenVPN and ETS interface - admin - 29.01.2025 Try adding mssfix 1400 to the ovpn configs for all clients (LM and your PC). RE: OpenVPN and ETS interface - Frank68 - 28.03.2025 (29.01.2025, 11:40)admin Wrote: Try adding mssfix 1400 to the ovpn configs for all clients (LM and your PC). Hello I have access to a network via openvpn, where I already see devices that respond to my ping, instead the REACTOR does not respond to my ping and is not reachable, do I have to configure something also in the openvpn client on the reactor? Isn't it visible directly being on the same network? Thank you very much RE: OpenVPN and ETS interface - admin - 28.03.2025 Check that Reactor has valid Gateway settings. And if you have full network access via VPN then why do you need to configure VPN on Reactor? RE: OpenVPN and ETS interface - Frank68 - 28.03.2025 (28.03.2025, 14:41)admin Wrote: Check that Reactor has valid Gateway settings. And if you have full network access via VPN then why do you need to configure VPN on Reactor? I don't want to configure VPN on REACTOR the problem is that it is not visible on the VPN even having all the right parameters. RE: OpenVPN and ETS interface - admin - 28.03.2025 Explain your setup. As mentioned before check that Reactor has valid Gateway settings. RE: OpenVPN and ETS interface - Frank68 - 28.03.2025 (28.03.2025, 15:01)admin Wrote: Explain your setup. As mentioned before check that Reactor has valid Gateway settings. I have REACTOR Config IP 10.255.28.140 SN 255.255.255.240 GW 10.255.28.129 DNS 172.23.1.16 2 display panels with the same parameters except IP respond without problems, the 2 panels see the REACTOR, the problem is the external visibility from the VPN. thnak's RE: OpenVPN and ETS interface - admin - 28.03.2025 Maybe there's something wrong with the OpenVPN server setup. That's out of our support scope, check with the IT who setup the VPN |
