Shelly - Logic Machine - Printable Version
+--- Thread: Shelly - Logic Machine (/showthread.php?tid=5880)
Shelly - Logic Machine - linux_sun - 10.02.2025
I’m trying to connect a Shelly device to Logic Machine. I have configured the MQTT broker on LM, and the Cloud MQTT is working correctly. However, I’m having trouble setting up the MQTT client or rather, I’m not sure how to configure it properly. Could someone share a practical example of a configuration for sending an On and Off command to Logic Machine and receiving them back, using group addresses?
Thanks!
RE: Shelly - Logic Machine - admin - 10.02.2025
https://kb.logicmachine.net/integration/shelly/#step-4---mqtt-client-configuration
RE: Shelly - Logic Machine - cuongcv - 24.09.2025
(10.02.2025, 10:49)admin Wrote: https://kb.logicmachine.net/integration/shelly/#step-4---mqtt-client-configuration
Dear Admin,
How many Shelly device one LM can handle?
Thank you.
RE: Shelly - Logic Machine - admin - 24.09.2025
Something like 100-200 should be fine.
(24.09.2025, 11:09)admin Wrote: Something like 100-200 should be fine.
Thank you so much
