Open VPN Setting - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: Open VPN Setting (/showthread.php?tid=5893) |
Open VPN Setting - Frank68 - 20.02.2025 Hello in a remote connection system I am switching from Zerotier to OpenVPN at the customer's request, on my computer I have the OPenVPn client configured, but when I try to connect to the LM, from inside the VPN network nothing to do it does not even respond to Ping, in the LM I have to configure something to use OpenVPN, I am already on the LM network but it is not reachable. Thank you very much RE: Open VPN Setting - admin - 20.02.2025 Check OpenVPN server configuration. client-to-client option must be enabled. RE: Open VPN Setting - Frank68 - 17.03.2025 (20.02.2025, 07:35)admin Wrote: Check OpenVPN server configuration. client-to-client option must be enabled. need to configure this on LM, or only on the server setting? Thanks RE: Open VPN Setting - admin - 17.03.2025 It's a server setting. |
