Wiser KNX app. Show object value - Printable Version
+--- Thread: Wiser KNX app. Show object value (/showthread.php?tid=5915)
Wiser KNX app. Show object value - Engine - 06.03.2025
Hello. I use Wiser For KNX "LSS100100" and Wiser KNX app. I have an object "Voltage" that contains information about  network voltage and has units "V" (it can be for example 220V). I want to show this value in Wiser KNX app (i use iPhone). How can i do this?
RE: Wiser KNX app. Show object value - Daniel - 06.03.2025
This app is 100% developed by SE so you should contact SE for help.
You probably need to add it to Touch.
RE: Wiser KNX app. Show object value - Erwin van der Zwart - 06.03.2025
Voltage is not (yet) possible, only (Active) Power by using the energy app, this gives you the option to add a widget to a certain room with the measured value.
See: https://www.productinfo.schneider-electric.com/wiser-knx/0000956364-wiser-knx-aug/English/Wiser_KNX_app_0001139974.xml
