DALI on LM5 Reactor Dimmer KNX (i.MX6) - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: DALI on LM5 Reactor Dimmer KNX (i.MX6) (/showthread.php?tid=5916) |
DALI on LM5 Reactor Dimmer KNX (i.MX6) - Chandrias - 07.03.2025 I am relatively new to the use of LM, so forgive me for my ignorance. I managed to connect 1 DALI device to my LM. I can see the three control objects (On/Off, 4-bit & Scale), but I can see nowhere any feedback objects. Are there any? RE: DALI on LM5 Reactor Dimmer KNX (i.MX6) - Daniel - 07.03.2025 These are the old generation of DALI which is not evolving as we moved this to our CANx extensions and in there you have everything. This solution works fine but it is very limited. For feedback you will need a script, see this https://forum.logicmachine.net/showthread.php?tid=2665&pid=17130#pid17130 RE: DALI on LM5 Reactor Dimmer KNX (i.MX6) - Chandrias - 07.03.2025 (07.03.2025, 12:43)Daniel Wrote: These are the old generation of DALI which is not evolving as we moved this to our CANx extensions and in there you have everything. This solution works fine but it is very limited. For feedback you will need a script, see this Is my LM compatible with the CANx extensions? RE: DALI on LM5 Reactor Dimmer KNX (i.MX6) - Daniel - 07.03.2025 There are two versions of Reactor dimmer, but most likely you have the KNX version and this will be no then. RE: DALI on LM5 Reactor Dimmer KNX (i.MX6) - Chandrias - 09.03.2025 (07.03.2025, 15:09)Daniel Wrote: There are two versions of Reactor dimmer, but most likely you have the KNX version and this will be no then. You are right. There is no CAN terminal on my device. Is it possible to change the short address of DALI devices? RE: DALI on LM5 Reactor Dimmer KNX (i.MX6) - Daniel - 10.03.2025 https://forum.logicmachine.net/showthread.php?tid=5470&pid=35346#pid35346 |
