blink light - Printable Version
+--- Thread: blink light (/showthread.php?tid=5934)
blink light - Andrea Becagli - 18.03.2025
I have flood sensor witch sends me an alarm in case of flood. When the alarm state is triggered i need to make a light blink constantly until the alarm stops.
I created an event-based script triggered by the state of the sensor and inside I created a while loop inside:
while grp.getvalue("stato sensore") do   grp.write("luce", true)   os.sleep(1)   grp.write("luce", false)   os.sleep(1) end
Now it works but it easily overloads the CPU pretty easily. Is there a better way to do this?
RE: blink light - admin - 18.03.2025
See if the script triggers something else. One telegram per second should not cause high CPU load.
Set event script execution mode to "Last instance only".
RE: blink light - Andrea Becagli - 18.03.2025
(18.03.2025, 10:02)admin Wrote: See if the script triggers something else. One telegram per second should not cause high CPU load.
Well, it does because the light is WLED led strip so it is not directly KNX but through API it became KNX. It actually works like this:
light group address >  triggers an event-based script > calls a function from the library i created
is that too much? Does using metatables heavily impact the CPU? I attached the TAG- activated event-script
ga = event.dst dt = grp.find(ga).datatype ga_stato = get_st_add(ga) value = event.getvalue() wled = wled_ctrl:init({ip = "10.11.24.106", debug_mode = false}) if dt==1001 then   wled:accensione(value, ga_stato) elseif dt == 5001 then   wled:luminosita(value, ga_stato) elseif dt == 232600 then   wled:colore(value, ga_stato) elseif dt == 6 then   wled:effetto(value, ga_stato) elseif dt == 7 then   wled:color_temp(value, ga_stato) elseif dt == 8 then   wled:palette(value, ga_stato) else   log("rec")   log(wled:stato()) end
Install System load app on LM and check which process is causing high CPU load. Sometimes I/O load can be high without actual high CPU load.
(18.03.2025, 11:05)admin Wrote: Install System load app on LM and check which process is causing high CPU load. Sometimes I/O load can be high without actual high CPU load.
Ok I found the problem, kind of stupid: since I have 15 WLED strips and I using a generated general command to switch them all off and back on, I was sendind 15 telegrams each second.
I solved using the API to directly switch on and off all the strips. I now have a way lower CPU usage.
