My lua script is not return the result that I want - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: My lua script is not return the result that I want (/showthread.php?tid=5948) |
My lua script is not return the result that I want - pouralise - 26.03.2025 I want to set v = false if condition true or otherwise v = nil. I use this code: Code: value = 4>3 and false or nilor Code: value = 3<4 and false or nilThe result always nil. Do you know why it's not work? How could I fix it. I want to write in shortway so I dont want to use if conditon. Well I ask google gemini and get the answer. thanks. RE: My lua script is not return the result that I want - djaval - 27.03.2025 Maybe try "if then else" construction? If indeed object can have nil value... RE: My lua script is not return the result that I want - myg - 27.03.2025 value = 4>3 and false or nil value = 4<3 and false or nil you always get NIL because result of the first expression ([ANY] AND FALSE) is always FALSE by definition (because you have FALSE as one of the operands in AND construct) if you want to use this construct, you can use number 0 instead of boolean value. RE: My lua script is not return the result that I want - pouralise - 28.03.2025 (27.03.2025, 09:25)myg Wrote: value = 4>3 and false or nil It's nice. thank you |
