Connect N4AIA08 to LogicMachine - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Connect N4AIA08 to LogicMachine (/showthread.php?tid=5950) |
Connect N4AIA08 to LogicMachine - Chandrias - 27.03.2025 I have a Modbus analog input device, which I would like to connect to my LogicMachine. I managed to connect to that device with my laptop and read the inputs. I also created the .json file, which I think it is correct. Any help on how to connect to my LogicMachine and read the inputs? Please keep in mind that this is the first time I work with Modbus, so there are a lot I still need to learn. RE: Connect N4AIA08 to LogicMachine - Daniel - 28.03.2025 Connect it to LM, set RTU settings and then use Read test and check if you can read the values. Drop screenshot of correct configuration. RE: Connect N4AIA08 to LogicMachine - Chandrias - 30.03.2025 (28.03.2025, 08:28)Daniel Wrote: Connect it to LM, set RTU settings and then use Read test and check if you can read the values. Drop screenshot of correct configuration. I managed to make it work just fine. Thank you. |
