Enable Scenes via LM5 - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: Enable Scenes via LM5 (/showthread.php?tid=5952) |
Enable Scenes via LM5 - vmic - 30.03.2025 Hi! I am having a KNX project in which I am using KNX devices that cannot create any scenes with it (Doesn't have any Scenes inside ETS parameters). Only simple On/off and just Up/Down and start /stop for the Shutters control. So, the only thing I have is Group addresses only for On/off and Shutters Control and I would like to create a scene for these controls that will Turn On Some Lights (not all) and opening all the shutters of the House. Is it possible to do that with the LM5 or not? What I have to do to create a scene that will be able to enable it from a switch and from inside the Mosaic App? Thank you in advance for your help! RE: Enable Scenes via LM5 - Daniel - 31.03.2025 Use Scenes is LM. there is dedicated tab for it. Alternatively you can use this but this will be only accessible from Mosaic https://youtu.be/LB96DfbQzM0 |
