Block Auto-size for iframe? - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: OLD visualization (https://forum.logicmachine.net/forumdisplay.php?fid=9) +--- Thread: Block Auto-size for iframe? (/showthread.php?tid=5963) |
Block Auto-size for iframe? - victor.back - 14.04.2025 Hi. Is there possible to block the auto-size setting for iframes in visualisation, tried using some additional CSS an additional classes but no success. Code: .iframeSpotRing {
height: 670px;
overflow-y: auto; /* for adding scrollbar if conent more then 670px */
transform: none !important; /* block autosize */
width: 100% !important;
pointer-events: all !important;
}RE: Block Auto-size for iframe? - admin - 14.04.2025 Can you explain your use case? transform is applied to the parent plan container element so resetting transform of the iframe won't change anything. RE: Block Auto-size for iframe? - victor.back - 15.04.2025 (14.04.2025, 07:03)admin Wrote: Can you explain your use case? transform is applied to the parent plan container element so resetting transform of the iframe won't change anything. I have set to auto-size in the visu settings. But for a specific iframe thats open in one plan, I would like to not have auto-size, is this possible? Because the iframe is for a smaler size than the actual plan thats supose to be shown here, so I want to be able to scroll down inside the iframe. But when tha auto-size is on the view inside the iframe gets auto scaled and result in too small view. Hope I get the explanation good enough |
