Script don't write to TP only to IP - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Script don't write to TP only to IP (/showthread.php?tid=5966) |
Script don't write to TP only to IP - stonecroft - 15.04.2025 Hello. I use the script "Logic functions and central statuses" from "examlpes". In my case i use the "or" function to show if any lights is on in rooms. The script works and the output object updates but it only write to IP side. If I connect my interface to TP side it doessent send. The TP connection works for other objekcts. The input to the logic all comes from TP side. Does anyone have a idé what I missing? RE: Script don't write to TP only to IP - admin - 15.04.2025 Replace grp.update with grp.write in the script. RE: Script don't write to TP only to IP - stonecroft - 15.04.2025 Thanks, that solved it! ? |
