Reactor dimmer knx - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Hardware (https://forum.logicmachine.net/forumdisplay.php?fid=12) +--- Thread: Reactor dimmer knx (/showthread.php?tid=5971) |
Reactor dimmer knx - gdimaria - 18.04.2025 I have to connect a thermal sensor ntc10k on reactor where to connect and how to configure? Thanks Peppe RE: Reactor dimmer knx - admin - 22.04.2025 You device has a 1-Wire port so you can use ds18b20 sensor instead. For NTC sensors you need an additional resistor to create a voltage divider. It should be connected like this: GND -- 10k fixed resistor -- I/O port -- NTC 10k sensor -- 24V Then you will need a script to calculate sensor resistance based on the I/O port voltage and convert resistance to temperature using a look-up table. The resulting accuracy might be quite low. |
