i cannot import knxproj to LM - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: i cannot import knxproj to LM (/showthread.php?tid=6000) |
i cannot import knxproj to LM - Simuzer - 20.05.2025 hi all, i have LM5 its seems I import the project. It says new objects have been added. But when I look at the objects, I cannot see the newly added ones. When I try to add them manually, it does not add them either. Firmwaer 20240426 Total objects 4716 i tried import KNXPROJ file, Import ESF file and run scripting.. But no new objects in list. RE: i cannot import knxproj to LM - Daniel - 20.05.2025 Read the options while importing knxproj. If you want existing objects to be updated you must select this option. RE: i cannot import knxproj to LM - Simuzer - 20.05.2025 i know. forexample; 1) by Import file; 23/0/1 ... 23/0/200 2) Add Object manually 23/0/1 No error, no fault. everyting is ok. But, there is no 23/0/1 on listing object page. Reboot.. cut off the energy.. Address 23/0/1 is not showing up. It does not appear in the list. RE: i cannot import knxproj to LM - Daniel - 21.05.2025 How old is the LM? It looks like you have faulty SD card with read only mode, this is very old issue. You will need to replace the SD card and flash it. https://kb.logicmachine.net/misc/reflash-lm-and-streaming-player/ RE: i cannot import knxproj to LM - Simuzer - 25.05.2025 i have two LM.. I noticed that one of the devices was an SN model. LM5Lp2 and LM5Lp2SN I took a backup from LM5Lp2 and loaded the backup into LM5Lp2SN. Total object over of 5.000 object. And no problem. LM5Lp2SN runs by over 5.000 object. But, new objects are not added by manually or import knxproj file. (i think its bug) But i can change page. Its run. No problem. I took a backup from LM5Lp2SN (with 5000 objects) and loaded the backup into LM5Lp2. But, in LM5Lp2 , new objects are not added by manually or import knxproj file. How to fix backup file ? RE: i cannot import knxproj to LM - admin - 26.05.2025 SN model is limited to 3500 objects. |
