Trend logs - Multiple Trends scaling/positioning - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Application Store (https://forum.logicmachine.net/forumdisplay.php?fid=11) +--- Thread: Trend logs - Multiple Trends scaling/positioning (/showthread.php?tid=6009) |
Trend logs - Multiple Trends scaling/positioning - Chandrias - 28.05.2025 When I select multiple trends in the trends log, the application adds the second trend only, in the right side, with different y-axis. Is it possible to select which trend goes with each y-axis and also define the values of the axis (i.e. min, max value) In my case, i have two temperature sensors, which i need to compare, so I need them both in the same y-axis. RE: Trend logs - Multiple Trends scaling/positioning - admin - 28.05.2025 Both objects must have the same units. RE: Trend logs - Multiple Trends scaling/positioning - Chandrias - 05.06.2025 (28.05.2025, 05:54)admin Wrote: Both objects must have the same units. Thanks |
