Pop UP Custom Value Height - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: OLD visualization (https://forum.logicmachine.net/forumdisplay.php?fid=9) +--- Thread: Pop UP Custom Value Height (/showthread.php?tid=6017) |
Pop UP Custom Value Height - sjfp - 07.06.2025 How can i adjust the size (Height) of a popup box. I have 7 custom values, but the pop up only show 5 of them, so you have to use the slider to show the missing 2 values. I there a way to show all 7 custom values so the user does need to use the slider ? Also need to enlarge the popup and center all popups to the center of the screen RE: Pop UP Custom Value Height - sjfp - 08.06.2025 (07.06.2025, 15:27)sjfp Wrote: How can i adjust the size (Height) of a popup box. I have 7 custom values, but the pop up only show 5 of them, so you have to use the slider to show the missing 2 values. Sorted, used the following in CSS .control-vselect .popover-content .nav { max-height: 250px; overflow-y: auto; } RE: Pop UP Custom Value Height - admin - 09.06.2025 Use this CSS to center the control and make it larger: Code: .control-vselect {
top: 50% !important;
left: 50% !important;
transform: scale(150%) translate(-50%, -50%) !important;
.control-vselect ul {
max-height: none;
}RE: Pop UP Custom Value Height - sjfp - 09.06.2025 Thank you for your help. Appreciated |
