eventlog.lp - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: eventlog.lp (/showthread.php?tid=6023) |
eventlog.lp - sjfp - 15.06.2025 Got this script working on LM devices we have, but trying to use this on a project which is using SE's C-BUS NAC / SHAC (MK 1 ), but unfortunately the scripts don't work. Is there something missing the C-BUS controllers which is preventing the script from working correctly. May be something like require('apps') RE: eventlog.lp - admin - 16.06.2025 Do you have anything in Error log? RE: eventlog.lp - sjfp - 16.06.2025 (16.06.2025, 06:45)admin Wrote: Do you have anything in Error log? There are no error log. The frame just doesn't show any information. I have setup the same as we do with any LM machines, so not sure why the NAC doesn't work. Changed eventlog/lp name in and the frame, when we do this frame shows file does not exist. So I know its looking at the correct folder and file name eventlog.lp We can see data in storage when we use items = storage.exec('lrange', 'eventlog', 0, 10) tex = table.concat(items, '\r\n') log(tex) RE: eventlog.lp - admin - 16.06.2025 Open browser Dev tools (F12), switch to Network tab and check the server response when eventlog.lp is loaded. RE: eventlog.lp - sjfp - 16.06.2025 (16.06.2025, 07:54)admin Wrote: Open browser Dev tools (F12), switch to Network tab and check the server response when eventlog.lp is loaded. Please see attached error with bootstrap.css and js/jquery that are not found. So think it may be associated with the require('apps') that may not be supported in NAC . Not sure though RE: eventlog.lp - admin - 16.06.2025 You can copy the missing files from LM via browser and then upload to user directory via FTP. Edit eventlog.lp and change /apps/js/ and /apps/css/ to /user/ RE: eventlog.lp - sjfp - 16.06.2025 Getting closer, now getting an error in the Vis frame "Error in /www/user/eventlog.lp at line 2: attempt to index global 'storage' (a nil value)" <? items = storage.exec('lrange', 'eventlog5', 0, 999) ?> I removed the require ('apps') as this is not being and change the store to eventlog5 so I can test a new. So the frame is throughing up error with storage.exec line RE: eventlog.lp - admin - 16.06.2025 It won't work without loading apps library. It should be present in the firmware since .lp handler works. RE: eventlog.lp - sjfp - 16.06.2025 Unfortunately back to nothing again. BUt no errors in Network Window anymore which is good I think. This is the Common Function script:- function eventlog(text) local max = 1000 -- max number of entries -- add formatted date text = os.date('%a %d/%m/%Y %T ') .. text storage.exec('lpush', 'eventlog5', text) storage.exec('ltrim', 'eventlog5', 0, max - 1) end This is what's in the eventlog.lp <? require('apps') items = storage.exec('lrange', 'eventlog5', 0, 999) ?> <!DOCTYPE html> <html> <head> <meta charset="UTF-8"> <title>Event log</title> <script src="/user/jquery.js.gz"></script> <link rel="stylesheet" href="/user/bootstrap.css"> </head> <body> <script> $(function() { var items = <? json.write(items) ?> , container = $('.container') , header; $.each(items, function(index, item) { var chunks = item.split(' ') , newheader = chunks.shift() + ' ' + chunks.shift(); // output data header each time it changes if (newheader != header) { header = newheader; $('<h3></h3>').text(header).appendTo(container); } // output log entry $('<p></p>').text(chunks.join(' ')).appendTo(container); }); }); </script> <div class="container"></div> </body> </html> For testing used in Event Script eventlog(event.getvalue()) log(io.ls('/data/apps/store/user')) log(storage.exec('lrange', 'eventlog5', 0, 999)) This gives back in log:- Event for 0/1/0 16.06.2025 14:43:45 * table: [1] * string: eventlog.lp [2] * string: bootstrap.css.gz [3] * string: jquery.js.gz [4] * string: bootstrap.css [5] * string: log.txt Event for 0/1/0 16.06.2025 14:43:45 * table: [1] * string: Mon 16/06/2025 14:43:45 7 [2] * string: Mon 16/06/2025 14:12:39 239 [3] * string: Mon 16/06/2025 14:12:30 150 RE: eventlog.lp - admin - 16.06.2025 Open /user/eventlog.lp directly in your browser, press CTRL+u to view the page source and post what you get. RE: eventlog.lp - sjfp - 16.06.2025 <!DOCTYPE html> <html> <head> <meta charset="UTF-8"> <title>Event log</title> <script src="/user/jquery.js.gz"></script> <link rel="stylesheet" href="/user/bootstrap.css"> </head> <body> <script> $(function() { var items = ["Mon 16\/06\/2025 14:43:45 7","Mon 16\/06\/2025 14:12:39 239","Mon 16\/06\/2025 14:12:30 150"] , container = $('.container') , header; $.each(items, function(index, item) { var chunks = item.split(' ') , newheader = chunks.shift() + ' ' + chunks.shift(); // output data header each time it changes if (newheader != header) { header = newheader; $('<h3></h3>').text(header).appendTo(container); } // output log entry $('<p></p>').text(chunks.join(' ')).appendTo(container); }); }); </script> <div class="container"></div> </body> </html> RE: eventlog.lp - admin - 16.06.2025 .lp file works correctly. Most likely jquery cannot be loaded. Check browser console (F12) for any errors. RE: eventlog.lp - sjfp - 16.06.2025 Thanks for the help. error was the jquery.js.gz file so extract to just jquery.js and then changed eventlog.lp to /user/jquery.js Now working thank you for all the help. |
