Bacnet client - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Application Store (https://forum.logicmachine.net/forumdisplay.php?fid=11) +--- Thread: Bacnet client (/showthread.php?tid=6032) |
Bacnet client - Haug1 - 21.06.2025 Hi. I'm experiencing that the bacnet client app don't update alle values very often. And very often it only updates some of the values not all.. I have tried the bacnet script. But do i have to uninstall the client app first? i get this error: Bacnet test 21.06.2025 22:16:20 Resident script:1: module 'bacnet' not found: no field package.preload['bacnet'] no file './bacnet' no file 'Library bacnet' no file 'Library bacnet' no file 'Library bacnet.so' stack traceback: [C]: in function 'require' RE: Bacnet client - Daniel - 23.06.2025 Bacnet client app is struggling when too many objects are used. Use script and yes uninstall the client app. You need the scada bacnet package. https://dl.openrb.com/lm-24-imx6/pkg/ RE: Bacnet client - Zoli - 14.08.2025 Hi, Is it possible to somehow decrypt the contents of the BACnet client? It seems that too many devices have been added to it and maybe that's why it won't start. The app doesn't load, only the progress indicator spins. I would like to write it in a script, but unfortunately I didn't save the data points. I tried to restore a previous save, where even fewer BACnet devices were added, but the app didn't start either. Thank You! RE: Bacnet client - admin - 14.08.2025 Install Storage viewer app. RE: Bacnet client - Zoli - 14.08.2025 (14.08.2025, 08:16)admin Wrote: Install Storage viewer app. Thank you! It was a bit tricky to extract the data, but I got it! |
