Bluetooth USB Dongle - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Bluetooth USB Dongle (/showthread.php?tid=6033) |
Bluetooth USB Dongle - jmir - 23.06.2025 Hi, Should bluetooth work on a LM4 (i.MX28) firmware 20211215? I've a Belkin F8T065bf dongle but when I connect It to USB port it seems that LM doesn't detect it (on system status --> serial ports doesn't appear...) If I'm not wrong several years ago I used it in this device... Thanks. RE: Bluetooth USB Dongle - AEK - 24.06.2025 (23.06.2025, 10:57)jmir Wrote: Hi, check system config - status - system log. is there any records when you connect usb? RE: Bluetooth USB Dongle - jmir - 24.06.2025 (24.06.2025, 07:14)AEK Wrote:(23.06.2025, 10:57)jmir Wrote: Hi, Hi, I've managed to make it work. I think that the problem was that packages were not the last version... Thanks! |
