.lp enable/disable - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: .lp enable/disable (/showthread.php?tid=6035) |
.lp enable/disable - Novodk - 23.06.2025 Is it possible to enable/disable a /user/*.lp file via a script? RE: .lp enable/disable - admin - 25.06.2025 Create a virtual group address and check the value in .lp script: Code: <?
require('apps')
enabled = grp.getvalue('32/1/1')
if not enabled then
return
write('lp enabled') |
