Problem acces remote on VPN - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: Problem acces remote on VPN (/showthread.php?tid=6038) |
Problem acces remote on VPN - Frank68 - 26.06.2025 hello I have 2 supervisor panels that point to a reacton, although all three respond to ping the reactor is seen offline in the android panels I see the pages, but if I try to access from a computer in the same VLAN I can't access VISU. As a VPN I use OPEN VPN, for external access. Where could the problem be? Thanks RE: Problem acces remote on VPN - admin - 26.06.2025 Are you using OpenVPN on Reactor? If so then disable redirect-gateway option if it's present. RE: Problem acces remote on VPN - Frank68 - 30.06.2025 (26.06.2025, 14:04)admin Wrote: Are you using OpenVPN on Reactor? If so then disable redirect-gateway option if it's present. where do i disable gateway redirector? thank's RE: Problem acces remote on VPN - admin - 30.06.2025 In OpenVPN config. |
