Problem with HomeKit integration and temperature sensor - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Problem with HomeKit integration and temperature sensor (/showthread.php?tid=6047) |
Problem with HomeKit integration and temperature sensor - demis.c - 07.07.2025 Hi, I created a virtual object on Logic Machine with address 32/1/1. I need to interface this virtual object with a temperature sensor. I can control the temperature sensor through a series of APIs, so that’s not the issue. The problem is that the object, configured as shown in the attached screenshots, does not appear in HomeKit, even though I’ve configured it properly. It’s the only object that doesn’t show up. If I load any other object into HomeKit—except a temperature sensor object—it is displayed correctly. I tried with another Logic Machine, and by configuring the object in the same way, it does appear in HomeKit. Could you please help me? Thank you. RE: Problem with HomeKit integration and temperature sensor - admin - 07.07.2025 How many HomeKit objects (virtual devices) do you have? There's a hard limit of 150 objects. RE: Problem with HomeKit integration and temperature sensor - demis.c - 07.07.2025 I currently have 81 devices in HomeKit. I also have 8 virtual devices. If I add any other device, virtual or not, as long as it's not a temperature sensor (for example, a simple switch), it shows up without any problem. What could be the issue? RE: Problem with HomeKit integration and temperature sensor - admin - 08.07.2025 Try clearing Homekit cache (trash bin button in the LM app) and pair again. This might be helpful too: https://forum.logicmachine.net/showthread.php?tid=4722&pid=39344#pid39344 |
