Modbus master - connect failed - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Modbus master - connect failed (/showthread.php?tid=6052) |
Modbus master - connect failed - cgn - 18.07.2025 I've a W4k, which I want to use as modbus master and slave. With the IP .128 W4k is a modbus slave. The script for this workes fine. With the IP .129 W4K should be a modbus master. I've created and imported a modbus profile. The objects of this profiles are mapped as well. Any idea why the connect failes? RE: Modbus master - connect failed - admin - 18.07.2025 Looks like you are try to connect master to itself. Is the device you want to connect to Modbus TCP or RTU? |
