Special delay - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Special delay (/showthread.php?tid=6057) |
Special delay - AndersH - 23.07.2025 Hi. I think i makes everything more difficult than it has to be.. ![]() I want to have a script (maybe eventbased), when i get 1 on the incoming adress i want to send a 30min delayed % value to the outgoing adress. If incoming is 0, nothing will happen. Best regards RE: Special delay - Daniel - 23.07.2025 See this: https://forum.logicmachine.net/showthread.php?tid=3932&pid=26134#pid26134 RE: Special delay - AndersH - 23.07.2025 Think i got it... --event based if event.getvalue(1) then --Delay value = 1 os.sleep(60*30) value = 11 grp.write('32/1/2', value) else end RE: Special delay - Daniel - 23.07.2025 In this case make sure to set the execution mode to last instance only. RE: Special delay - AndersH - 23.07.2025 What do you mean with that ? RE: Special delay - Daniel - 23.07.2025 https://app.screencast.com/Zck27WZ4EUGlj |
