1-wire stop reporting - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: 1-wire stop reporting (/showthread.php?tid=6071) |
1-wire stop reporting - fiLLLip - 05.08.2025 Hi, I have been using the LM with 1-wire for 6-7 years now, and it suddenly stopped reporting. Could it be a faulty sensor causing issues for the remaining two, or do you have any suggestions? RE: 1-wire stop reporting - admin - 05.08.2025 Start by checking the voltage on both 1-wire terminals - +5V and DATA. Then disconnect sensors one by one and check if other sensors can be read. RE: 1-wire stop reporting - fiLLLip - 29.08.2025 (05.08.2025, 07:03)admin Wrote: Start by checking the voltage on both 1-wire terminals - +5V and DATA. Then disconnect sensors one by one and check if other sensors can be read. Voltage was OK. Disconnected all sensors and tested one by one to verify that one of them was faulty. Replaced and now working
