how to sort the names listed ? - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: OLD visualization (https://forum.logicmachine.net/forumdisplay.php?fid=9) +--- Thread: how to sort the names listed ? (/showthread.php?tid=6084) |
how to sort the names listed ? - Simuzer - 21.08.2025 Hi all, How can we sort the names listed on the left side under the widget ? For example in alphabetical order ? It is very difficult for me to find the widget like this. Is there a solution for this? Thank you for your helps. its ok on "Vis. Structure".. But its not ok "visualization" RE: how to sort the names listed ? - admin - 21.08.2025 This will be fixed in the next firmware. Meanwhile you can run this script to fix the sort order. Code: function sort(itype)
local query = 'SELECT id, name FROM visfloors WHERE type=?'
local items = db:getall(query, itype)
table.sort(items, function(a, b)
return a.name < b.name
end)
for i, item in ipairs(items) do
db:update('visfloors', { sortorder = i }, { id = item.id })
sort('widget')
sort('layout')RE: how to sort the names listed ? - Simuzer - 21.08.2025 (21.08.2025, 07:13)admin Wrote: This will be fixed in the next firmware. Its ok ! Thank you a lot. |
