modbus communcation error - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: modbus communcation error (/showthread.php?tid=6093) |
modbus communcation error - balatis - 27.08.2025 Hello everyone ! I face an issue with modbus commmunication with a heat pump. I atttach you the script and manual. I checked it with the app "modbus polling", it works properly and I read data from the pump. But via lm i have no communication. Have you any idea about it ? The json-profile: { "manufacturer": "GREE", "description": "pump", "mapping": [ { "name": "Water Tank Temperature", "datatype": "uint16", "type": "register", "address": 13, "unit": "°C" } ] } RE: modbus communcation error - Daniel - 27.08.2025 Start by using Read test, check wiring and correct RTU settings. RE: modbus communcation error - balatis - 27.08.2025 (27.08.2025, 09:50)Daniel Wrote: Start by using Read test, check wiring and correct RTU settings. We have already done these steps, but no response. The wiring and the rtu settings are correct. RE: modbus communcation error - Daniel - 27.08.2025 Did you try swapping A/B? RE: modbus communcation error - balatis - 28.08.2025 (27.08.2025, 10:11)Daniel Wrote: Did you try swapping A/B? Yes, we tried but nothing changed. We connected it to port 2 in the same LM and it works properly. After that we changed LM and it works properly in port 1, because in this project we use port 2 for ekey. So, the port 1 does not work in the first LM. RE: modbus communcation error - Daniel - 28.08.2025 OK then contact us via email for replacement. |
