Recommended amount of BACnet export points - Printable Version
+--- Thread: Recommended amount of BACnet export points (/showthread.php?tid=6099)
Recommended amount of BACnet export points - Rune - 02.09.2025
When using the LogicMachine5 Lite as a BACnet GW, with your experience, what is the recommended amount of points per LM5? 300, 500, 1000?
What is our experience regarding max points per gateway in bigger projects?
RE: Recommended amount of BACnet export points - Daniel - 02.09.2025
It all depend of all the other things LM has to do but 2k is a fairly safe number. It can do more if done properly.
