trends name - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: trends name (/showthread.php?tid=6101) |
trends name - hocine - 02.09.2025 Hello Is it possible to retrieve the trends names for display in an application? I would like to create a LogicMachine interface where clients can select trends from a dynamically generated list based on available curves. THX RE: trends name - Daniel - 02.09.2025 Try this Code: query = 'SELECT name FROM trends'
for _, object in ipairs(db:getall(query)) do
name=tostring(object.name or '')
log(name)
endRE: trends name - hocine - 02.09.2025 (02.09.2025, 14:14)Daniel Wrote: Try thisI try this but i don't have all the trends Code: local rows = db:getall("SELECT id, name FROM trends ORDER BY name COLLATE NOCASE")
for _, r in ipairs(rows or {}) do
log(string.format('%s (id=%s)', tostring(r.name or ''), tostring(r.id or '')))
if not rows or #rows == 0 then
log('[db-trends] Aucun enregistrement trouvé dans la table trends (ou table vide).')
RE: trends name - Daniel - 03.09.2025 how many trends do you have? RE: trends name - hocine - 03.09.2025 (03.09.2025, 06:56)Daniel Wrote: how many trends do you have? i have 34 trends RE: trends name - Daniel - 03.09.2025 Check the logs in LogicMachine Log tab. RE: trends name - hocine - 04.09.2025 (03.09.2025, 12:43)Daniel Wrote: Check the logs in LogicMachine Log tab. thx |
