Question about CANX DALI Gateway circuit protection - Printable Version
+--- Forum: CANx (https://forum.logicmachine.net/forumdisplay.php?fid=23)
+--- Thread: Question about CANX DALI Gateway circuit protection (/showthread.php?tid=6105)
Question about CANX DALI Gateway circuit protection - shinsuke imai - 06.09.2025
We are considering adopting the CANX DALI Gateway, powered by an 18V PSU.
I would like to confirm the following:
If the DALI bus of the CANX DALI Gateway is short-circuited, where does the circuit protection operate — on the PSU side or within the Gateway itself? I mean that in case of a short circuit, will the 18V PSU continue to operate normally, or will it be affected?
It would be ideal if the PSU could continue running even during a short circuit on the DALI bus.
Thank you in advance for your support.
Best regards
RE: Question about CANX DALI Gateway circuit protection - admin - 08.09.2025
Yes, you can use one 18V power supply for multiple CANx-DALI device DALI lines.
