HomeLYnk keep restarting - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Hardware (https://forum.logicmachine.net/forumdisplay.php?fid=12) +--- Thread: HomeLYnk keep restarting (/showthread.php?tid=6109) |
HomeLYnk keep restarting - khalil - 10.09.2025 Hello Dears, I have a HomeLYnk in an old site, I try to take a backup but it failed donload several times, I notice the LED of the device turn off and on again, seems that the device restart continouslly every several minutes. could this issue be solved be a new FW or SDcard Flash? RE: HomeLYnk keep restarting - Daniel - 10.09.2025 It is most likely some programming issue. Stop all scripts and see it it helped. What is the CPU/Memory/Disk info? RE: HomeLYnk keep restarting - khalil - 10.09.2025 (10.09.2025, 07:08)Daniel Wrote: It is most likely some programming issue. Stop all scripts and see it it helped. What is the CPU/Memory/Disk info? there is no script at all! but the device around 13 years old CPU/Memory/Disk info are normalĀ the device is lightly used RE: HomeLYnk keep restarting - Daniel - 10.09.2025 If it is that old it could be anything, I would probably start from replacing the SD card. Run it with an empty project, if same will happen then something is damaged on the hardware. RE: HomeLYnk keep restarting - khalil - 15.09.2025 Thank you Could I restore HL backup on SL, or should I use Wiser KNX RE: HomeLYnk keep restarting - Daniel - 15.09.2025 It will work but the firmware must be equal or newer. |
