Suggestion to create a frame in a page - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Visu (https://forum.logicmachine.net/forumdisplay.php?fid=24) +--- Thread: Suggestion to create a frame in a page (/showthread.php?tid=6120) |
Suggestion to create a frame in a page - Domoticatorino - 18.09.2025 Hi there, I would like to insert in a page (Plan View) like a widget object view but it must be always shown. As you know widget appear only when icon is selected. I tried to find a solution using an image object but even if I set border color and dimensions of border in appearance tab I see a white image without border. How can I do that please? Thanks. BR RE: Visu: suggestion to create a frame in a page - Daniel - 18.09.2025 Why don't you just copy all elements from that widget and paste on the plan? RE: Visu: suggestion to create a frame in a page - Domoticatorino - 18.09.2025 (18.09.2025, 08:58)Daniel Wrote: Why don't you just copy all elements from that widget and paste on the plan? Hi Daniel, sorry but probably I was not clear. Please find enclosed the example. As you can see there are 4 square. In the example there are the same objects but obviously there will be different. Thank you for your help. Regards. RE: Visu: suggestion to create a frame in a page - Daniel - 18.09.2025 I still see no problem, you can select them and duplicate 4 times. RE: Visu: suggestion to create a frame in a page - Domoticatorino - 18.09.2025 (18.09.2025, 10:12)Daniel Wrote: I still see no problem, you can select them and duplicate 4 times. Ok, probably I cannot see it. What it is the the widget to draft the square with border? Thanks. BR RE: Visu: suggestion to create a frame in a page - Daniel - 18.09.2025 For that you will need to use some image. There were some suggestions to create a shape widget. RE: Visu: suggestion to create a frame in a page - Domoticatorino - 18.09.2025 (18.09.2025, 10:22)Daniel Wrote: For that you will need to use some image. There were some suggestions to create a shape widget. I enclosed the images widget. Even if I set border width and color of the border it is not work as shown. In this case the image choosen is only and example. But this to show you that border does not change as I set. Thanks. BR RE: Visu: suggestion to create a frame in a page - Daniel - 18.09.2025 I was thinking about image like this The Appearance settings for image are only applied to Tile view. For now I think this is the only way. RE: Visu: suggestion to create a frame in a page - Domoticatorino - 18.09.2025 (18.09.2025, 10:51)Daniel Wrote: I was thinking about image like this Yes, it is the same. I used the image to show you that on the plan view the border of the image widget does not work. In your opinion can be upgrade? Thanks. RE: Visu: suggestion to create a frame in a page - Daniel - 18.09.2025 We will think what is the best way for such task. RE: Visu: suggestion to create a frame in a page - Domoticatorino - 07.10.2025 (18.09.2025, 11:46)Daniel Wrote: We will think what is the best way for such task. Dear Daniel, further to the same thread, is it possible custom the page (frame, background and so on) config using CSS script as per "Visualisation" app? Could you give any example please? Thanks. RE: Visu: suggestion to create a frame in a page - admin - 08.10.2025 Please specify what exactly you want to customize so we can provide an example. RE: Visu: suggestion to create a frame in a page - Domoticatorino - 08.10.2025 (08.10.2025, 07:04)admin Wrote: Please specify what exactly you want to customize so we can provide an example. Hi admin, I would like to customise the frame of the pages and of the widgets as I wrote in the previous chat. See also in the image provide by Daniel. Thanks. BR RE: Visu: suggestion to create a frame in a page - Domoticatorino - 15.10.2025 (08.10.2025, 08:24)Domoticatorino Wrote:(08.10.2025, 07:04)admin Wrote: Please specify what exactly you want to customize so we can provide an example. HI DANIEL! I have seen the update on the last package Visu. Well done. Thanks. |
