Control Nefit boiler - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Control Nefit boiler (/showthread.php?tid=6128) |
Control Nefit boiler - gjniewenhuijse - 26.09.2025 I like to control a Nefit boiler that has an EMS protocol. Its not possible to control it directly so i inserted an EMS-ESP into my system. Now i can get data from my system with this script Code: --[[
Nefit heat pump ems bus
https://bbqkees-electronics.nl/wiki/gateway/restful-api.html
https://docs.emsesp.org/Commands/
ems-esp/boiler {"cmd":"heatingactivated", "data":"on"} turn on heatingactivated in boiler
ems-esp/boiler/heatingactivated {"data":"on"} turn on heatingactivated in boiler (equivalent to command above)
ems-esp/boiler {"cmd":"dhw.disinfecting", "data":"on"} turn on DHW disinfecting in boiler
https = require('ssl.https')
json = require('json')
ltn12 = require('ltn12')
iDebug = true
devIp = '192.168.x.xx' -- ems-esp.local
devUrl = 'http://'..devIp..'/api/'
function getData(iFunction)
if iDebug then log(devUrl..iFunction) end
res, code = https.request({
url = devUrl..iFunction,
method = 'GET'
if iDebug then
log(code, res)
return code, res
function setData(iFunction, iData)
method = 'POST',
headers = {["content-type"] = "application/json"},
data = iData
if iDebug then
log(code, res)
return code, res
-- get system info
--getData('system')
-- get boiler info - GET outputs current EMS device information in verbose
--getData('boiler/info')
-- get boiler values - GET outputs current EMS device information in short format
--getData('boiler/values')
-- get boiler - GET same as values above
--getData('boiler')
-- get boiler commands - GET lists the available command entities to call
--getData('boiler/commands')
-- get boiler entities - GET lists all enabled entities
--getData('boiler/entities')
-- get boiler dhw info
--getData('boiler/dhw/info')
-- get boiler entity heatingactive
--getData('boiler/heatingactive')
-- thermostaat streeftemperatuur
--getData('thermostat/seltemp')
-- dhw Laden
--getData('thermostat/dhw/charge')
setData('thermostat/dhw/charge', '{"value": true}') --curl -X POST http:///api/system/dhw/charge -H "Content-Type: application/json" -d '{"value": true}'I also like to control the data with the setData function (last line). But i received an error 400. Whats wrong with my code? Documentation can be found here: https://docs.emsesp.org/Commands/ RE: Control Nefit boiler - admin - 26.09.2025 You are missing Content-Length header for the POST request. Code: ["Content-Length"] = #iData,You should use json.encode instead of writing JSON manually to avoid potential errors. RE: Control Nefit boiler - gjniewenhuijse - 26.09.2025 (26.09.2025, 12:58)admin Wrote: You are missing Content-Length header for the POST request. Like this (but with same error)? Code: setData('thermostat/dhw/charge', {value = true})
method = 'POST',
headers = {["Content-Type"] = "application/json",
data = json.encode(iData)
if iDebug then
log(code, res)
return code, res
endRE: Control Nefit boiler - admin - 26.09.2025 Try this: Code: setData('thermostat/dhw/charge', {value = true})
local data = json.encode(iData)
method = 'POST',
headers = {
["Content-Length"] = #data
data = data
if iDebug then log(code, res) end
return code, res
endRE: Control Nefit boiler - gjniewenhuijse - 26.09.2025 (26.09.2025, 13:13)admin Wrote: Try this: Other error: * arg: 1 * string: closed * arg: 2 * nil RE: Control Nefit boiler - admin - 26.09.2025 Are you sure that URL endpoint and parameters are correct? RE: Control Nefit boiler - gjniewenhuijse - 26.09.2025 (26.09.2025, 13:27)admin Wrote: Are you sure that URL endpoint and parameters are correct? getData for that endpoint works and the result is: * arg: 1 * number: 200 * arg: 2 * string: {"name":"charge","fullname":"dhw Laden","circuit":"dhw","bool":false,"index":0,"value":"uit","type":"boolean","readable":true,"writeable":true,"visible":true} RE: Control Nefit boiler - admin - 26.09.2025 Send a request to http://<hostname>/api/<device>/commands to get a list of available commands. Do you have access token enabled in Security->Manage Users? RE: Control Nefit boiler - gjniewenhuijse - 26.09.2025 (26.09.2025, 13:39)admin Wrote: Send a request to http://<hostname>/api/<device>/commands to get a list of available commands. Do you have access token enabled in Security->Manage Users? Access token is disabled In the output i need the command: ,"dhw[n].charge":"Laden" Output: {"info":"lijst van alle waardes","values":"list all values","commands":"lijst van alle commando's","entities":"lijst van alle entiteiten","[hc<n>.]boost":"boost mode","[hc<n>.]boosttime":"boost time","[hc<n>.]comforttemp":"Comforttemperatuur","[hc<n>.]control":"Afstandsbedieding","[hc<n>.]controlmode":"Comtrolemodus","[hc<n>.]cooloffdelay":"cooling off delay","[hc<n>.]coolondelay":"cooling on delay","[hc<n>.]coolstart":"cooling starttemp","[hc<n>.]cooltemp":"Temperatuur koelbedrijf","[hc<n>.]designtemp":"Ontwerptemperatuur","[hc<n>.]dewoffset":"Offset dauwpunt","[hc<n>.]dhwprio":"Prioriteit warm water","[hc<n>.]ecotemp":"Temperatuur eco","[hc<n>.]fastheatup":"Snel opwarmen","[hc<n>.]heatingtype":"Verwarmingstype","[hc<n>.]heatoffdelay":"heat-off delay","[hc<n>.]heatondelay":"heat-on delay","[hc<n>.]hpcooling":"WP koelbedrijf","[hc<n>.]hpminflowtemp":"Minimale aanvoertemperatuur WP","[hc<n>.]hpmode":"Modus warmtepomp","[hc<n>.]hpoperatingmode":"Bedrijfsmodus warmtepomp","[hc<n>.]instantstart":"instant start","[hc<n>.]intoffset":"Offset interne temperatuur","[hc<n>.]manualtemp":"Temperatuur handmatig","[hc<n>.]maxflowtemp":"Maximale aanvoertemperatuur","[hc<n>.]minflowtemp":"Minimale aanvoertemperatuur","[hc<n>.]mode":"Modus","[hc<n>.]nofrostmode":"Vorstbeveiligingsmodus","[hc<n>.]nofrosttemp":"Temperatuur vorstbeveiliging","[hc<n>.]noreducetemp":"Reduceermodus onderbreken onder","[hc<n>.]offsettemp":"Temperatuur offset","[hc<n>.]program":"Programma","[hc<n>.]redthreshold":"reduction threshold","[hc<n>.]reducemode":"Gereduceerde modus","[hc<n>.]reducetemp":"Onderste afschakeltemperatuur","[hc<n>.]remotehum":"room humidity from remote","[hc<n>.]remotetemp":"Ruimtetemperatuur van afstandsbediening","[hc<n>.]roominflfactor":"Factor ruimteinvloed","[hc<n>.]roominfluence":"Ruimteinvloed","[hc<n>.]roomtempdiff":"Verschiltemperatuur kamertemp","[hc<n>.]seltemp":"Streeftemperatuur kamer","[hc<n>.]solarinfl":"solar influence","[hc<n>.]summersetmode":"Instelling zomerbedrijf","[hc<n>.]summertemp":"Zomertemperatuur","[hc<n>.]switchonoptimization":"Inschakeloptimalisering","[hc<n>.]switchprogmode":"switch program mode","[hc<n>.]tempautotemp":"Streeftemperatuur automodus tijdelijk","absent":"absent","building":"Type gebouw","damping":"Demping buitentemperatuur","datetime":"Datum/Tijd","delayboiler":"Vertragingsoptie","dhw[n].charge":"Laden","dhw[n].chargeduration":"Laadtijd","dhw[n].circmode":"Modus circulatiepomp","dhw[n].dailyheating":"Dagelijks opwarmen","dhw[n].dailyheattime":"Tijd dagelijkse opwarming","dhw[n].disinfectday":"Desinfectiedag","dhw[n].disinfecting":"Desinfectie","dhw[n].disinfecttime":"Desinfectietijd","dhw[n].mode":"Modus","dhw[n].settemp":"Streeftemperatuut","dhw[n].settemplow":"Onderste streeftemperatuur","electricfactor":"Energiefactor electrisch","energycostratio":"Energiekostenratio","fossilefactor":"Energiefactor fossiele brandstof","hybridstrategy":"Hybride strategie","intoffset":"Offset interne temperatuur","minexttemp":"Min. buitentemperatuur","pvenabledhw":"Verhoging WW activeren","pvlowercool":"Verlagen koeling met PV activeren","pvraiseheat":"Verwarmen met PV activeren","solar":"solar","switchovertemp":"Schakeltemperatuur buitentemperatuur","tempdiffboiler":"Verschiltemperatuuroptie"} RE: Control Nefit boiler - admin - 26.09.2025 Try sending true instead of {value = true}. If this does not help then you should ask this question here: https://github.com/emsesp/EMS-ESP32/discussions RE: Control Nefit boiler - maxmp - 26.09.2025 Fyi: Theben has an Opentherm to KNX gateway and there is an Opentherm to EMS converter. I have this setup and it works very well. RE: Control Nefit boiler - gjniewenhuijse - 29.09.2025 (26.09.2025, 21:00)maxmp Wrote: Fyi: Theben has an Opentherm to KNX gateway and there is an Opentherm to EMS converter. I have this setup and it works very well. Which Openterm to EMS converter do you use? And can you control the DHW charge? (Extra warm water function) RE: Control Nefit boiler - maxmp - 06.10.2025 (29.09.2025, 08:58)gjniewenhuijse Wrote:(26.09.2025, 21:00)maxmp Wrote: Fyi: Theben has an Opentherm to KNX gateway and there is an Opentherm to EMS converter. I have this setup and it works very well. Hi. I have this gateway: https://www.robbshop.nl/nefit-ems-opentherm-converter Regarding the DHW, i don't use this function, but i see its status. RE: Control Nefit boiler - gjniewenhuijse - 07.10.2025 (06.10.2025, 06:52)maxmp Wrote:(29.09.2025, 08:58)gjniewenhuijse Wrote:(26.09.2025, 21:00)maxmp Wrote: Fyi: Theben has an Opentherm to KNX gateway and there is an Opentherm to EMS converter. I have this setup and it works very well. Thanks, and is it also possible to control this status? RE: Control Nefit boiler - gjniewenhuijse - 08.10.2025 (26.09.2025, 14:05)admin Wrote: Try sending true instead of {value = true}. If this does not help then you should ask this question here: https://github.com/emsesp/EMS-ESP32/discussions If i try the same with Postman it works great, so why it doesnt work from the LM? POST /api/thermostat/dhw/charge HTTP/1.1 Host: 192.168.x.x Content-Type: application/json Content-Length: 16 {"value": false} RE: Control Nefit boiler - admin - 08.10.2025 Replace data = data with body = data in https.request({...}). RE: Control Nefit boiler - gjniewenhuijse - 08.10.2025 Thanks.. now it works |
