Syncing doesn't work on cloud - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: Syncing doesn't work on cloud (/showthread.php?tid=6132) |
Syncing doesn't work on cloud - Nir70 - 29.09.2025 hello Remote connection What router port should i need to open on his home router? Syncing doesn't work for me in the cloud. Thanks RE: Syncing doesn't work on cloud - Novodk - 29.09.2025 TCP 443 and 8883, and remember to set gateway and DNS, I don't know what error code 14 is- RE: Syncing doesn't work on cloud - admin - 01.10.2025 Make sure that LM has valid gateway and DNS settings in System config > Network > Interfaces > eth0. See if you can ping remote.logicmachine.net from System config > Status > Network utilities. RE: Syncing doesn't work on cloud - Nir70 - 03.10.2025 (01.10.2025, 07:18)admin Wrote: Make sure that LM has valid gateway and DNS settings in System config > Network > Interfaces > eth0. Hello, I get a ping. Regards. RE: Syncing doesn't work on cloud - Daniel - 03.10.2025 Ping remote.logicmachine.net or 168.119.164.110 RE: Syncing doesn't work on cloud - Nir70 - 04.10.2025 (03.10.2025, 10:58)Daniel Wrote: Ping remote.logicmachine.net or 168.119.164.110 hi i get ping attached RE: Syncing doesn't work on cloud - Nir70 - 04.10.2025 (04.10.2025, 06:32)Nir70 Wrote:(03.10.2025, 10:58)Daniel Wrote: Ping remote.logicmachine.net or 168.119.164.110 Thanks, the problem is solved. I disabled the firewall And the connection was made & synchronization i turned the firewall back on router and then still connected . Thanks for all the advice, best regards
RE: Syncing doesn't work on cloud - Daniel - 06.10.2025 Only outgoing ports are needed, you could add exception in your firewall. You can block all incoming ports. |
