Cloud problem - Printable Version
+--- Thread: Cloud problem (/showthread.php?tid=6140)
Cloud problem - CristianAgata - 06.10.2025
Good morning,
I have a strange behavior in the cloud. I have all sync but if I open the link in remote.logicamchine.net it says LM not connected to the cloud. I have already clean the cache, change the connession key but nothig I always see the page of "Fioriera Doppia".
In the attached file some Images.
If it can help you these are 3 LM5Cp2-rio3-LTE all three the same and for speed up the commissioning I created a back up and copy each other. Could be this the problem?
Best regards Cristian
RE: Cloud problem - Daniel - 06.10.2025
Did you create yourself a user with correct permissions?
RE: Cloud problem - CristianAgata - 06.10.2025
(06.10.2025, 13:32)Daniel Wrote: Did you create yourself a user with correct permissions?
Hi Daniel,
yes, take a look at my first post I change something in the description add some detail.
BR Cristian
There can be two possible issues.
1. If you create yourself a user in User access tab and use the same email as in cloud app then the settings in user access part have higher priority. It means if no permissions there then you have no access.
2. Cloud by default remember last visited network. Probably it navigates to the offline network and you must change to the online one. Or just delete the offline ones.
(06.10.2025, 13:45)Daniel Wrote: There can be two possible issues.
Ok,
so if i will try to make online the other server could I solve. Is it?
Hi Daniel,
I have connected the other machine and now I can see both the interface. Tomorrow I will go on the project and I will make the test.
Best regards and thanks for the tips.
Cristian
RE: Cloud problem - admin - 07.10.2025
If you have multiple networks then you can select the current active network in Mosaic top right corner:
In new Visu network selection is located at the bottom of the main menu.
RE: Cloud problem - CristianAgata - 07.10.2025
(07.10.2025, 07:02)admin Wrote: If you have multiple networks then you can select the current active network in Mosaic top right corner:
Ho Admin,
Thanks for your answer, I know this function, but when they was both on line, one disappeare and cloud let me see only one of both and not the only one on line. I hope to be cleared.
