aqara smoke detector - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: aqara smoke detector (/showthread.php?tid=6147) |
aqara smoke detector - Andrea Becagli - 09.10.2025 Hi, I'm working on a client's setup that uses a LogicMachine with a Zigbee gateway. We're currently adding several Aqara T1 temperature sensors, and the client would also like to install the Aqara Smoke Detector (model SD-S01E). I've checked the official LM compatibility list but couldn't find this specific model. Is it just not listed? Is it compatible with LM and if not could it be added? RE: aqara smoke detector - Daniel - 09.10.2025 Pair it and check. If it will not work post device information from the app. RE: aqara smoke detector - admin - 09.10.2025 It will pair and will work for some time. But it requires a certain message to be sent to it periodically otherwise it will drop off the network and won't join unless you reset it and pair again. It's not a reliable solution, choose a different smoke sensor. We've tested smoke sensor from Heiman and it works fine. |
