Visu admin: Widget "Select" not boolean - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Visu (https://forum.logicmachine.net/forumdisplay.php?fid=24) +--- Thread: Visu admin: Widget "Select" not boolean (/showthread.php?tid=6157) |
Visu admin: Widget "Select" not boolean - Domoticatorino - 15.10.2025 Hi, widget above accept only numeric value just like widget "numeric value" display. Only numeric value group address are accepted and not in boolean format. Is there a possibility to manage boolean as well? As you kno bit "true" means "switch on" but could be "WINTER" as well. Thank you for your usual help. BR RE: Visu admin: Widget "Select" not boolean - Daniel - 15.10.2025 You can use switch widget with value display, you can freely define text. RE: Visu admin: Widget "Select" not boolean - Domoticatorino - 15.10.2025 (15.10.2025, 13:36)Daniel Wrote: You can use switch widget with value display, you can freely define text. Oh Sorry Daniel. I did not think about that. Thanks. |
