Multiple multicast addresses - Printable Version
+--- Thread: Multiple multicast addresses (/showthread.php?tid=6167)
Multiple multicast addresses - Simuzer - 26.10.2025
How can I add multiple multicast addresses to only one logic machine?
Multicast Address:
  • 224.0.23.12
  • 224.0.23.13
  • 224.0.23.14
RE: Multiple multicast addresses - Daniel - 27.10.2025
This is not possible, what are you trying to solve?
RE: Multiple multicast addresses - Simuzer - 27.10.2025
(27.10.2025, 08:25)Daniel Wrote: This is not possible, what are you trying to solve?
Each block has an average of 18-20 floors.
Each block has an average of 20 floors. Each block has two main lines.
Below is an example physical addressing for block A1.
Quote:SECTION A1
(Floor 12 - 3)
-- 1.0.0 (Ip Router)
-- 1.1.0 (Line Coupler) (Floor 12)
-- -- 1.1.1 (Switch Actuator)
-- -- 1.1.2 (Sensor 1), 1.1.3 (Sensor 2), 1.1.4 (Sensor 3), etc.
-- 1.2.0 (Line Coupler) (Floor 11)
-- -- 1.2.1 (Switch Actuator)
-- -- 1.2.2 (Sensor 1), 1.2.3 (Sensor 2), 1.2.4 (Sensor 3), etc.
-- 1.3.0 (Line Coupler) (Floor 10)
-- -- 1.3.1 (Switch Actuator)
-- -- 1.3.2 (Sensor 1), 1.3.3 (Sensor 2), 1.3.4 (Sensor 3), etc.
-- 1.15.0 (Line Coupler) (Floor 3)
-- -- 1.15.1 (Switch Actuator)
-- -- 1.15.2 (Sensor 1), 1.15.3 (Sensor 2), 1.15.4 (Sensor 3), etc.
(Floor 2 - (-5))
-- 2.0.0 (Ip Router)
-- 2.1.0 (Line Coupler) (Floor 2)
-- -- 2.1.1 (Switch Actuator)
-- -- 2.1.2 (Sensor 1), 2.1.3 (Sensor 2), 2.1.4 (Sensor 3), etc.
-- 2.2.0 (Line Coupler) (Floor 1)
-- -- 2.2.1 (Switch Actuator)
-- -- 2.2.2 (Sensor 1), 2.2.3 (Sensor 2), 2.2.4 (Sensor 3), etc.
-- 2.3.0 (Line Coupler) (Floor 0)
-- -- 2.3.1 (Switch Actuator)
-- -- 2.3.2 (Sensor 1), 2.3.3 (Sensor 2), 2.3.4 (Sensor 3), etc.
-- 2.15.0 (Line Coupler) (Floor -5)
-- -- 2.15.1 (Switch Actuator)
-- -- 2.15.2 (Sensor 1), 2.15.3 (Sensor 2), 2.15.4 (Sensor 3), etc.
Blocks and knx physical addresses are as follows. As you can see, there are 3 addresses from 1.x.x. (red, blue and green). But IP Router IP addresses and group addresses of all devices are different.
i have only one Logic Machine..
Can't I solve this with 1 LM? Or do I need 3 LMs for 3 regions?
I hope I was able to explain it. I'm looking forward to any suggestions you may have.
Section A1 Block
-- 1.x.x
-- 2.x.x
Section A2 Block
-- 3.x.x
-- 4.x.x
Section B1 Block
-- 5.x.x
-- 6.x.x
Section B2 Block
-- 7.x.x
-- 8.x.x
Section M Block
-- 9.x.x
-- 10.x.x
Section N1 Block
-- 11.x.x
-- 12.x.x
Section N2 Block
-- 13.x.x
-- 14.x.x
Section C1 Block
-- 1.x.x
-- 2.x.x
Section C2 Block
-- 3.x.x
-- 4.x.x
Section D1 Block
-- 5.x.x
-- 6.x.x
Section D2 Block
-- 7.x.x
-- 8.x.x
Section E1 Block
-- 9.x.x
-- 10.x.x
Section E2 Block
-- 11.x.x
-- 12.x.x
Section F1 Block
-- 1.x.x
-- 2.x.x
Section F2 Block
-- 3.x.x
-- 4.x.x
Section G1 Block
-- 5.x.x
-- 6.x.x
Section G2 Block
-- 7.x.x
-- 8.x.x
Section H1 Block
-- 9.x.x
-- 10.x.x
Section H2 Block
-- 11.x.x
-- 12.x.x
RE: Multiple multicast addresses - Daniel - 28.10.2025
How many group addresses is all this? What is the task for LM on this project?
RE: Multiple multicast addresses - Simuzer - 28.10.2025
(28.10.2025, 08:05)Daniel Wrote: How many group addresses is all this?  What is the task for LM on this project?
A total block will be around 600-1000. Therefore, the total maximum will be 12000-17000 group addresses.
The LM's job here is to monitor and turn lamp states on and off. It can also change sensor times.
LM's tasks:
  • Monitoring lamp status
  • Controlling lamp on/off
  • Changing regional sensor timings when necessary
You need at last 3 LM to have 4-5k objects per each. If you need some global scheduling/settings you can use MQTT to communicate between LMs. How is the network done? KNX IP works only on one subnet.
