Use of address_scale with read_count and read_offset Modbus Profiles - Printable Version
+--- Thread: Use of address_scale with read_count and read_offset Modbus Profiles (/showthread.php?tid=6174)
Use of address_scale with read_count and read_offset Modbus Profiles - merlin - 01.11.2025
Hi i Hope this is relative simple question
When using read_count and read_offset features in a modbus profile,  can i use address_scale in the same process and if so what value do you use for address_scale, the offset from the block read point or the actual address.
I have in fact tried both and Neither work I know when using the  read_count and read_offset  on there own return the correct value, but when using with  address_scale I just get 0 back.  Examples of what i have tried below from my profile,  i have tested each of these with no address_scale using the block read and i get results  so i know the registeres and offsets are all working fine.   and note the SF location are all in the block that is read
/* I_AC_Current (A)  @40071, SF @ Address Location 40075 */
    { "name": "I_AC_Current", "type": "register",
      "address": 40069, "read_count": 50, "read_offset": 2,
      "datatype": "uint16", "bus_datatype": "float32",
      "address_scale": 40075, "units": "A",
      "value_nan": [65535], "value_default": 0
    /* I_AC_CurrentA (A) @40072, SF @ Offset Location */
    { "name": "I_AC_CurrentA", "type": "register",
      "address": 40069, "read_count": 50, "read_offset": 3,
      "address_scale": 6, "units": "A",
    /* I_AC_VoltageAN (V) @40079, SF Note Defined (this works)*/
    { "name": "I_AC_VoltageAN", "type": "register",
      "address": 40069, "read_count": 50, "read_offset": 10,
      "units": "V",
Any help here would be appreciated.
If you have to ask why using block read,  it is because i need to get all values back with the same time stamp  for calculations,  reading each item individually introduces errors .
RE: Use of address_scale with read_count and read_offset Modbus Profiles - admin - 03.11.2025
Reading scale register value in a block is not supported. Scale register must be defined as any other register but with "internal": true, so its value is read before normal data registers. If you really need to read everything in a single request then use a script.
