PA - Printable Version
+--- Thread: PA (/showthread.php?tid=6178)
PA - rw_echo - 06.11.2025
Can LM read the physical address of KNX devices through the KNX IP routing mode?
RE: PA - admin - 06.11.2025
What exactly do you want to achieve? Functions like buslib.ping() should work over routing if "Pass ind. telegrams via IP Routing" is enabled.
RE: PA - rw_echo - 25.11.2025
(06.11.2025, 07:49)admin Wrote: What exactly do you want to achieve? Functions like buslib.ping() should work over routing if "Pass ind. telegrams via IP Routing" is enabled.
I want to enable LM to read the physical address status of KNX devices under other KNX branches through IP routing. Is this possible?
RE: PA - admin - 25.11.2025
Possible, you need to enable "Pass ind. telegrams via IP Routing" option in System config > Network > KNX connection.
